Jun 02 14:00:04 LivingRoom systemd[1]: Started RoonBridge.
Jun 02 14:00:07 LivingRoom start.sh[749]: Initializing
Jun 02 14:00:07 LivingRoom start.sh[749]: 00:00:00.039 Info: Starting /opt/…r
Jun 02 14:00:07 LivingRoom start.sh[749]: 00:00:00.080 Info: ConnectOrStart…r
Jun 02 14:00:07 LivingRoom start.sh[749]: Not Running (.o)
Jun 02 14:00:09 LivingRoom start.sh[749]: Running
Hint: Some lines were ellipsized, use -l to show in full.
pi@LivingRoom:~ $ aplay -l
aplay: device_list:268: no soundcards found…
I powered cycled the dac and get the same thing. No soundcard found. If i connect dac straight to dac Roon sees it no problem.
The ‘dtparam=audio=on’ line does not apply to your DAC – it’s only for enabling/disabling the onboard audio (analog/HDMI).
Try disabling that line again and reboot your Pi with the DAC powered on and try running aplay again.
When your DAC is visible in Roon – can you post a screenshot of the Playback tab in Roon (Settings > Audio > Gearbox icon next to your DAC > Settings > Playback)?
Thanks Rene. Working now. That explains why I couldn’t see the Pi. Onboard audio off and Pi not seeing DAC. I guess the only unanswered question would be why the Pi wasn’t recognizing the dac. Is there a specific order I should connect and power up the dac?
Hmmmmm, just put my raspberry pi plus hifiberry digi+ in a nice new case and now I’, not seeing it as an option in Roon.
I can access it in putty, I had the pi shut down for the past few days waiting for the case but I could log in no trouble and it remembered my previous log in last Sunday.
Is there anything diagnostically I can do to help me figure out where the issue may be?
Well… Roon Bridge appears to be OK… But your Digi+ is not seen by Alsa. You could try
sudo aplay -l
to be sure, but this does not look good.
Are you certain the assembly of the Digi+ on the GPIO headers is OK? Can you try to take it apart again and reassemble? Perhaps even try Pi & Digi+ outside of your brand spanking new life-enhancing case? And to be absolutely certain, check if
I’m afraid this will not help: you have now loaded the onboard sound modules (analog minijack and HDMI), but still no sign of the Hifiberry. As the onboard sound is not in use, it’s better left commented-out.
Pausing as in stopping the music or as in hiccups? Only with highres or with regular Redbook as well? Wired or Wifi?
I’ve got a Pi3 on Wifi running 100% reliably, but it’s within line of sight of my AEX 6 meters away. At other places, I’ve found it is having a hard time sustaining the connection, which can lead to dropouts or temporary connection losses.
I don’t know if it has been addressed here, forgive me if so, but how would powerline Ethernet work for a Raspberry Pi Roonbridge set up? Wifi, as stated above, is not ideal.
Just thinking on ways to skin this cat without busting drywall or enduring dropouts.
Ethernet over power works fine for me, I use optical out which I’m presuming with my little knowledge gets rid of any junk that may be added by the power adapters.
Pausing as in someone hit pause. It’s only done it a handful of times. I push/click play and it plays again without a problem. It won’t continue to play until I manual do it.
The Pi 3 is hardwired to cable modem. Mac Mini is on wifi running Roon right next to the modem/router. Music is stored on an external at usb 2.0 speeds. Think the external could cause a pause? When I decide on a new computer the mini will only run Roon with everything on SSD.
Side note - the above confi has run perfectly for 4 days straight after the last pause. Might be time to upgrade and give the Pi a case.
