My airplay zone is up and running again after build 1413. Thanks software team!
Hi everyone,
Please update to the most recent build 1413 for the fix to the Airplay connection issues discussed in this thread.
We’re happy to read that the fix has so far relieved symptoms for many users. If you continue to experience the same symptoms as on 1407 after updating to 1413 across your devices, please create a new topic thread and we’ll inform development ASAP.
Also here the problem is solved, thnx!
Thanks! All sorted here.
issue seem solved
thx
All sorted now
