(By the way I am not using the spockfish script, I installed manually)
The thing is that the usage of the .desktop file is not up to Roon. The .desktop file is a property of the desktop environment, in my case Gnome. The desktop environment is able to display any valid .desktop file as a launcher in the GUI, and when the user clicks it, it will execute the command from the .desktop file’s Exec= line, resulting in a command just like when launched from your script. The .desktop files can be created by the user in a text editor or by a helper program like menulibre. The program to be launched by a .desktop file has no say about this.
While writing the above little theoretical excursion, I found the fix
Thank you for posting your script, which set me on the right track.
The problem was that my .desktop file was simply not valid: The “env” was missing from the Exec= line, which I realized only after a glance at your script. Now I also remember the cause: Previously I used a DRI_PRIME=1 variable (trying Roon running on the external graphics card) and I deleted this a few days ago. In error, must have deleted the “env” with it, and never realized that the .desktop file is failing because I never had to restart Roon or Gnome.
So nothing to do with the Roon update, only that the update made me try to restart Roon. I added the “env” back in and all is good. Thank you
