Roon Nucleus+ /OS Version 1.0 (build 159), Server Version 1.6 (build 401), Labs Software 1.0 (build 9)
Hardwired into Fortinet server
Meridian MC200 over Ethernet
Tracks (either imported or Tidal both local or downloaded) start and then after about 8/9 second they grind to a halt. The progress bar continues merrily on its way but no sound. Dragging the progress bar restarts the sound at the new point but then the same problem. If the progress bar runs into the next track the silence continues. Please help.
It has previously worked fine and the Nucleus works with the two other MC200 and a 818v3. I am not sure what you mean by playing to a system output of a remote though. Doesn’t the remote (ie iPad or desktop Roon) just tell the endpoint what to play?
Hmm - mystery deepens… I switched to use Control:Mac to see if the MC200 would work with that and it all appeared fine. I then switched back to Roon and reenabled the audio zone. Starting to play a track to check the signal path and it all now appears to work fine. Does reenabling the zone work as a sort of reset?
I attach the screen shots though for thoroughness.
