Roon does not find my Audio Audio Outputs on my Device
Windows 10 Pro Build 18363
Roon Core Version: 1.7 (610) 64bit
WiFi Network
Verbindungsspezifisches DNS-Suffix: home
Beschreibung: Intel® Wi-Fi 6 AX200 160MHz
Physische Adresse: ‎5C-80-B6-46-37-96
DHCP-aktiviert: Ja
IPv4-Adresse: 192.168.1.39
IPv4-Subnetzmaske: 255.255.255.0
Lease erhalten: Sonntag, 4. Oktober 2020 08:40:19
Lease läuft ab: Montag, 5. Oktober 2020 09:55:09
IPv4-Standardgateway: 192.168.1.1
IPv4-DHCP-Server: 192.168.1.1
IPv4-DNS-Server: 192.168.1.1
IPv4-WINS-Server:
NetBIOS über TCPIP aktiviert: Ja
IPv6-Adresse: 2a02:1205:5046:1080:482c:71db:8c4d:96f7
Temporäre IPv6-Adresse: 2a02:1205:5046:1080:4474:220e:165b:b876
Verbindungslokale IPv6-Adresse: fe80::482c:71db:8c4d:96f7%8
IPv6-Standardgateway: fe80::a2b5:49ff:fe19:a90%8
IPv6-DNS-Server: 2a02:1205:5046:1080:a2b5:49ff:fe19:a90
Realtek Audio Device of Laptop
Aune USB DAC connected on Laptop is Visible on other Laptops or PC’s
I got a New Laptop and installed Roon Application newest Version (1.7 610 64bit) but Roon does not list this device in the Audio Settings, means the “This Device” Listing is missing completely
Has anybody faced identicalk problems?
How did you solve it?
best regards
Marco
Try disabling the firewall.
Hah… thanks for the hint
I have usually used Kaspersky IS but on this Device a McAfee is preinstalled and was active.
With disabling the Firewall it works. Need to get Rid of McAfee :wink:
