Hi @Jim_Gatheral,
In the logs we see the following trace:
10/30 14:24:31 Trace: [streamingmediafile] finished caching https://streaming-std.qobuz.com/file
10/30 14:24:32 Warn: [zoneplayer] failed to start stream OpenHome.Net.ControlPoint.ProxyError: 2:Connection timed out
at OpenHome.Net.ControlPoint.Proxies.CpProxyAvOpenhomeOrgTransport1.SyncPlayAs (System.String aMode, System.String aCommand) [0x0001b] in <3deaa7333e174f27bbd18500ac7eed87>:0
at Sooloos.Broker.Transport.SongcastDirectZonePlayer.StartStream (Sooloos.Broker.Transport.StartStreamParameters ps) [0x001d7] in <3deaa7333e174f27bbd18500ac7eed87>:0
at Sooloos.Broker.Transport.ZonePlayerBase+<>c__DisplayClass67_0.<_StartStream>b__0 () [0x00047] in <3deaa7333e174f27bbd18500ac7eed87>:0
at Sooloos.Broker.Transport.ZonePlayerBase.Prepare (System.Action cb_done) [0x00000] in <3deaa7333e174f27bbd18500ac7eed87>:0
at Sooloos.Broker.Transport.ZonePlayerBase._StartStream () [0x00117] in <3deaa7333e174f27bbd18500ac7eed87>:0
10/30 14:24:32 Info: [Office] [zoneplayer] Open result (Queueing): Result[Status=Success]
10/30 14:24:32 Warn: [zone Office] Track Stopped Due to Error
10/30 14:24:32 Info: [zone Office] OnPlayFeedback StoppedEndOfMediaUnnatural
10/30 14:24:32 Debug: [zone Office] _Advance
10/30 14:24:32 Info: Alert: Transport: playback_start_error_unexpected
This error shows that Roon timed out when trying to connect to the Linn endpoint for streaming.
Do you by any chance have another PC around the house you can try to use as the Roon Core? It would be interesting to note if the same issues occur from two Core machines, to switch Cores you can use these instructions:
- Open Roon on the other PC you wish to try as the Core
- Roon Settings â General
- Disconnect
- On the âChoose your Coreâ screen, press âUse this PCâ
- If asked to Unauthorize, you can go ahead and do so. You are limited to one active Roon Core at a time but you are free to switch between them as often as youâd like.
- Verify if the same behavior occurs on the different PC
