Core: Elac Discovery DS-S101-G
Roon 1.5 (build 49) stable (32bit)
Firmware Version 1.3 (build 28) stable
Connected via ethernet cable directly to router
via optical output to amplifier
Hello guys
I am having since a few weeks sometimes connectivy issues as that Roon (on my ipad app) doesn’t play songs or skips them by saying network / connectivity problems or data stream problems. Usually they went away or a reboot of router and Elac solved the problem.
Not today. I rebooted both devices 3x. I cleared the cache of my Elac device in the settings. But it would not play any online song. Songs on a USB stick with FLACS I got connected to the Elac work fine. So the Elac device is working.
Now I logged out of Tidal in the settings of Elac (Ipad app) and I can’t login anymore. It says wrong user name. I checked on my mobile phone and I can login just fine. I also checked on my computer and I can login fine with my usual email&password.
So there seems to be a problem on my Roon on the Elac.
Thank you for any help!
Michel
