Intel NUC 5i5RYK 16Gb running Rock
TP Link Deco P9 mesh network, hard wired from node
CXN v2 wired Ethernet
Don’t know how to see that? 30,000 maybe?!
So, since the most recent update Roon will stop partway through tracks seemingly at random. The track will hang for 30 seconds or so, and then either
a)go to the next track, or
b)go to the Roon-ready screen on the CXN V2
If it goes to the next track, I can skip back and it will then play the full track. This is happening on Roon radio, and I have only noticed it on tracks I know for sure aren’t local files.
All this has started since the last update.
