Nucleus
Sky Router (alas) but wifi turned off
Orbi mesh system
Naim Muso (original)
43191
I used to have a system that worked perfectly. Then Sky Q came into my life and I’m rather stuck.
I have a Sky router (no bridge mode alas).
But to cover my whole house I have an Orbi mesh system in AP mode (which means no access to IGMP proxying).
If I leave my Sky router wifi on I can connect to Roon via that network, albeit rather slowly.
However, if I turn off the Sky router wifi and then try to connect to Roon over my Orbi network I get the dreaded Initializing screen. All my iPads and iPhones now cannot connect to Roon.
So temporarily I am running with both wifis switched on and switch network any time I want to access Roon. This is very wearisome.
I know I should be able to solve this but I am totally stumped.
From your pages I am now using dyndns.org.
Any more tips? What info do you need?
Here is the relevant section from the log
01/18 14:57:53 Info: [brokerserver] Client connected: 192.168.0.94:59282
01/18 14:57:53 Trace: [raat] [sood] Refreshing device list
01/18 14:57:53 Trace: [raatserver] [sood] Refreshing device list
01/18 14:57:53 Trace: SENT NONFINAL DistributedBroker.ConnectResponse={ BrokerId=cf59d129-f177-424d-865a-ee62d9fe3b7e BrokerName='Nucleus' }
01/18 14:57:53 Trace: SENT NONFINAL DistributedBroker.UpdatesChangedResponse={ IsSupported=True WasJustUpdated=False Status='UpToDate' HasChangeLog=False CurrentVersion={ MachineValue=100800884 DisplayValue='1.8 (build 884) stable' Branch='stable' } }
01/18 14:57:53 Trace: [push] restarting connection (Unable to read data from the transport connection: Software caused connection abort.)
01/18 14:57:53 Trace: [push] retrying connection in 88886ms
01/18 14:57:53 Info: [brokerserver] Client disconnected: 192.168.0.94:59282
01/18 14:57:53 Info: [brokerserver] Client connected: 192.168.0.94:59283
01/18 14:57:53 Trace: [raat] RAATServer discovered: RaatServer Slugphone @ 192.168.0.94:9200
01/18 14:57:53 Info: [raatserver] GOT SERVER 7c00ed6b-c5c0-4084-9b13-d87a72e851ac::d73a2b17-dd2d-4250-8d97-90540d447873 @ 192.168.0.94:9200 Slugphone PROTOVER=1 RAATVER=1.1.38
01/18 14:57:53 Trace: [raatserver] [RaatServer Slugphone @ 192.168.0.94:9200] connecting (attempt 1)
01/18 14:57:53 Trace: [raatserver] [RaatServer Slugphone @ 192.168.0.94:9200] connected
01/18 14:57:53 Trace: [rnet/RnetJsonClient] SENT {"request":"enumerate_devices","subscription_id":"0"}
01/18 14:57:53 Trace: [rnet/RnetJsonClient] GOT NONFINAL {"status": "Success", "devices": [{"device_id": "default", "auto_enable": true, "auto_name": "Slugphone", "type": "ios", "name": "Slugphone", "vendor": "Apple", "model": "iPhone14,3", "is_system_output": true, "config": {"unique_id": "16783ecd-7768-5ef9-ca98-bd022b216f83", "external_config": {"is_private": true}, "output": {"type": "ios", "device": "default", "name": "iPhone"}, "volume": {"type": "ios", "device": "default"}}}]}
01/18 14:57:53 Info: [raatserver] GOT DEVICE d73a2b17-dd2d-4250-8d97-90540d447873::default Type=ios Name=Slugphone Vendor=Apple
01/18 14:57:53 Debug: [easyhttp] [37503] POST to https://discovery.roonlabs.net/1/query returned after 409 ms, status code: 200
01/18 14:58:00 Info: [stats] 24677mb Virtual, 2757mb Physical, 825mb Managed, 444 Handles, 91 Threads
