Synology DS720 running DSM 7
Roon 1.8 build 1021
Wired gigabit ethernet
Lyngdorf TDAI-1120
Google Pixel 5
179 albums, not many tracks
After not using Roon for a few days, it seemed to have lost connection to Qobuz. It also could not reconnect to Qobuz. I tried to stream Qobuz to the Lyngdorf or the Pixel 5 but there was no sound. The Signal Path indicator was not lit at all, so nothing was streamed.
I even tried to remove Qobuz under Settings/Services and log in again. However, the login screen just hangs there.
I was able to use Roon to stream local library tracks to the Lyngdorf.
Roon was able to reconnect to Qobuz after I restarted the Roon service on the Synology.
