Roon is up-to-date. The latest version is installed last week.
miniDSP SHD Studio > DAC > pre-amp > amplifier > speakers
Bluesound Node 2 > integrated amplifier
Schiit Modi 3 to Magni to headphones
Apple Home Pod Mini
Mainly in Tidal library (c. 150,000 tracks)
Music on flash drive about 200 GB. (currently 399 albums)
No NAS, 2 Samsung USB Flash Drives (128 GB x2) inserted to NUK.
I’ve been using Roon for the last 6 months without any problem. Today, the roon suddenly lost connection to the core and popped the “Lost Connection” error. This would last for 2 minutes up to 5 minutes & then it finds the core but it has never stayed connected for longer than 7 minutes without loosing the connection again. No changes had been made to the network. Everything remained the same but it started to happen. The system tries to reconnect to the core and connects to the core after 3 to 5 minutes of endless loop, but loses the connection again and popped “Lost Connection” error. It only stays connected for 2 to 7 minutes (actually timed) before losing the connection again - the issue repeating. Sometimes, it cannot re-establish the connection until I reboot the system, then loses the connection again after a few minutes. Can you run the diagnostics? I am quite frustrated.
The screenshot is attached.
Note: no problem accessing \ROCK\data while the system is trying to reconnect to the core.
The Roon software was removed from the remotes I am using (on the controlling PC, iPhone, iPad) and reinstalled again but drop outs occur regardless of the remote or interface.
I tried a different core (my la-top - Window) to run Roon in the same network・Had no issues at all. Just my dedicate roon core (ROCK) is having this reported issue.
I’m seeing a similar issue on Ubuntu. I tried uninstalling and reinstalling Roon, but the problem persists. I keep seeing the attached screenshot in the logs when I get dropped. Probably a coincidence, but Airplay seems to cut it out more than playing via Ropieee.
Now I am receiving this new problem after I attempted to restore one of my backups. Roon doesn’t let me log-in. Checked the internet connection but it has no problem.
James_I
(The truth is out there but not necessarily here)
#6
Some of these look like different issues. For clarity, mine is temporary - every time I wake up my win10 remote, the core seems to be sluggish and connects/disconnects repeatedly for a few minutes. Then it seems fine, albeit I have not had much of a chance to play with it. This is new behavior I have never seen before, seems to coincide with build 918.
Now I wanted to try logging in with a different core - my laptop (running Windows) but receive this screen. I cannot unauthorized the ROCK. The “Unauthorize” button is not responding.
Did the suggestion from Andrew resolve your issues? I think this might have worked for me but I now have the new issue which prevent me logging in to my account.
James_I
#13
This appeared to have worked for me, but time will tell. I deleted that folder (or actually renamed it) and then woke up my Win10 remote machine and it seemed to connect and be able to maintain it. We’ll see if that changes tomorrow.
Also, the intermittent drop-out problem was fixed. Only complaint is that it takes too long to load the library at the start up after rebooting the Roon Server but I can live with that for now. Now I got my favourite toy back!
