Quiet PC Windows10 pro 64 bit, Intel I5 CPU, 16GB RAM
Main Library Storage area Samsung T5 1TB USB-C SSD
BT Smarthub 6 router, wifi via Linksys Velop & Trendnet Eco network switches. Core ethernet to router.
Core connected, via USB, to Chord Mscaler dual bnc to Hugo tt2
Additional endpoints Muso, MusoQB, iMac.
Controlled via iPad 12.9pro, iPhone XR. iMac 24”
Library Size
26k+ tracks
Roon has recently started issuing the error message “ Roon lost control of the audio device ” on 24bit flac files (not all) but only with the Chord WASAPI driver, the ASIO driver works normally. Files up to 88.2khz are unpredictable & sometimes fail after around 5 seconds but anything above that rate fails immediately.
This affects streamed files (Qobuz) and locally stored files.
I have removed & reinstalled the Chord drivers & transferred the data files onto an internal hard disc but this hasn’t resolved the problem.
My broadband connection has been tested by the local engineer, sessions proved stable and speeds consistent at 42/15.
Any ideas to resolve this frustration would be welcome.
Thanks in advance.
