Just to update everyone, the new release of Home Assistant (2023.1) contains two Roon related fixes:-
Home Assistant, in some case, would have trouble reconnecting to Roon core after a disconnect. This was particularly a problem for people who turned off their cores overnight. This was a problem with one of the underlying libraries, which has had many issues sorted. So I’m optimistic this will fix those reconnection issues.
When playing music from a script or automation, you specify a path like Genres/Pop. This worked fine until you wanted to play anything that includes a backslash character. The code now allows you to quote the path ie Genres/“Pop/Rock”
The change contributed by @jmvdv discussed above to fix the volume adjustment on some endpoints has now been merged into home assistant and so should be part of the 2023.2 release next month.
Thanks so much for this Roon Module. I’ve been using it the last few months and had been great to get basic controls from Alexa working along with some basic scripts.
One thing I’d like to do would be to have certain scripts run from different user profiles. Currently all scripts are run through my main profile, but find that is impacting my “what have you been listening to” and “recently played” items within Roon.
The use case I have is that I have a playlist that’s on shuffle for the kids that triggers daily as an alarm for them. But the issue I have is now my profile on roon is blighted by their playlist music. Are there any ways to specify the user as part of the script / sequence in Home Assistant?
Thanks for the response! I guess one way would be to set my Profile as not the main profile as those stats are not being updated. But this would mean starting with a fresh profile.
Hi all, I’ve been finding Home Assistant really successful as a quick UI for Roon. Combined with some extra integrations on both sides (e.g. logitech harmony remotes) it’s working really well, but access to the “Pause All” interface that shows up inside the Roon Remote would make it perfect.
I can show all my zones together, however it would be great to have one consistent spot to simply pause anything playing. Is this possible? (I see on the Home Assistant page that you can supposedly target all players, but I can’t seem to get this to work at all).
I’m also interested in transferring between zones (which it also claims to support) but realistically I’d probably use the real remote.
I will check the pause command working on multiple endpoints.
But it’s very easy to write a home assistant script that would pause each player in turn, and attach that to a button in home assistant.
The transfer between endpoints command should work (it did when I tested it during development!). It’s similar to the group function (which I know works because I use it every day!).
