That looks fantastic, and very many thanks for your kind help!
Have searched how to create an alarm screen, but found nothing that seemed relevent. Would you, by any chance, have a link towards some reading I could start off with, please? Thanks again!
Did you have any success working this out please?
Would greatly appreciate some direction on how to crack wildcard search from Assist to play to a Roon endpoint if anyone has figured it out.
Example implementation for Spotify (using Spotcast rather than Roonlabs):
Exactly, very nice… planning on this too! but need proper Roon control for my endpoint to justify migrating all my Alexa routines and linked automations over.
How do you all deal with HA updates killing integrations that may or may not keep up to date…i.e. developers that write code to solve a problem or enable an integration but then rarely come back to update to keep current with core changes?
I like what I’ve got working in HA currently but after repeated Core/Supervisor and/or OS updates killing functionality I use I’ve blocked all updates.
I wish there was a LTS version instead of the rapid fire Wild West updates…or is there? I’m running bootable OS on RPi4.
Most of the time I haven’t seen issues caused by HA core/supervisor updates. If some functionality has been broken the fix is added a few days later normally. If the fix takes longer I just restore my HA VM of the day before. I use HAOS and a lot of unsupported and old integrations.
Thanks, yeah I’ve had to restore a few times and I’d rather not have the hassle/downtime/interrruption. I don’t care about security updates as my device is well protected otherwise…I’ll just keep treating it like an appliance to let it continue to do its job as is.
Option 1 change nothing. That way your system is stable, the only thing that could break it is changing external dependencies (HA itself is local - so all that might break are integration that have cloud dependencies). For Roon users the main risk are changes to Roon Core that might break the HA integration.
Option 2 keep everything fairly up do date. So you take all the HA / OS component update in a pretty timely manner. This means you get all the fixes in a co-ordinated way.
The roon integration doesn’t change much. I rarely add new features - and the roon api hasn’t changed for a while. There was a breaking change between 1.8 and 2.0 roon core that broke the HA Integration and required an urgent release.
So for HA with Roon you won’t miss much with Option 1
I do Option 2 just to stay on top of what’s happpeneing in case I need to adapt the integration.
Anything breaking I would warn people here.
The roon API could really use an update (eg to add smart playlists) so it wouldn’t surprise me if they did change something soon.
I’ll describe what I am trying to do, maybe I’m not approaching this right: I’ve got a number of playlists on Tidal that I can play through the house with Roon. I want to have a HA dashboard where I can pick a playlist and play it, pause it, etc.
One player is “modius”. After registering this with MA, I get “modius_2”. My issue is that when I direct “modius_2” to play, it instead plays “modius” which has a different playlist attached to it.
You obviously have modius registered as a name already in HA. This could be from a previous config but could also happen if your endpoint supports multiple protocols (e.g. chromecast/airplay).
The actual HA name doesn’t matter much. If you look further up I’ve done dashboards for all the play/pause etc and am happy to assist if those don’t make sense. The only thing I haven’t done messed with is playlists… i always start the music from Roon itself.
The HA Roon integration will attempt to create HA devices for any endpoints in roon, but as you create and delete endpoint - the old ones can remain in HA.
If you uninstall the HA roon integration, restart your HA system, and then re-add (and enable) the integration this should clear out any unused endpoints.
I usually find it easiest to initially get things working using the HA GUI and developer test tools, and the once working turn them into scripts / buttons etc - so would recommend you add the media players into your HA gui - then it’s easier to make sure you’re interacting with the player you expect.
Navigating the play_media command is a bit tricky, you can see the documentation here.
Based on what I see for Qobuz - I’d expect your path to your own Tidal playlist to be something like
“Tidal/My Tidal/ Playlists/myplaylisthere”
But what I normally do is to use the media browser in HA (each media player gui has one) to find the path to the playlist / album I want. I then convert this into a script.
If it doesn’t work as you expect the error message in the HA log should help you work out why the path isn’t working.
Thanks for the feedback. I’ve tried this both with and without Music Assistant. That is where my ‘modius_2’ comes from; MA automatically generates this player. I’ve been unable to get a working path to Tidal playlists so I’m going to try MA again.
I’m wondering if I can use ‘Modius’ and this will control ‘Modius_2’ or if I can join them.
