Tom_K
(Tom Keenan)
July 7, 2019, 8:52pm
#1
Roon isn’t consistently displaying Processing Speed in my controller window’s signal path box.
Sometimes it’s there, sometimes not. Usually not.
The last time I got it to display was after restarting the Mac Mini that runs my Core.
Thoughts? Troubleshooting ideas?
BrianW
(Brian)
July 7, 2019, 8:59pm
#2
It doesn’t show if the processing speed goes over 99. Sounds like you have no problems.
Tom_K
(Tom Keenan)
July 7, 2019, 10:55pm
#3
Oh. I guess I need to give Mac Mini more work to do.
For instance if I enable Sample Rate Conversion, then Processing Speed does show up (at 22.4X). If only I had the ears to hear the difference.
Thanks Brian, I learned something!
system
(system)
Closed
July 9, 2019, 11:07am
#4
