I have installed on an IMac the room server, and on a tablet and on a MacBook Pro also but not a server, on the tablet and on the MacBook Pro it does not recognize the audio outputs, only the audio outputs of the server that is on the iMac appear, which may be the problem since I have a FIIO dongler and on the tablet and on the MacBook Pro the Roon program does not recognize it.
My home network is simple, I have 2 APs that are connected to the same network, I don't have fw in between and my ISP link is from a provider,
Can you please navigate to macOS System Settings > Privacy & Security > Local Network , and make sure Roon is allowed. If it is already enabled, toggle it off and on again. Then reboot your Mac, and see if the same issue persists.
Hi @mario_alday,
Thanks for reaching out to us about this. Do you have a firewall running on the computer with Roon Server? If you do you’ll need to add exceptions for Roon, RoonServer and RAATServer. Please try that out and let us know if it helps!
