281445 tracks. Yes, over two hundred and eighty one thousand tracks
Cannot play DSD 512 files using my Roon Nucleus+ and MSB Select DAC..
This should absolutely, positively not be happening!
The problem is that there is a bug in the Roon Audio setup for MSB DACs:
Going to the Device Setup inside the Audio tab in settings, the only options for DSD in my MSB DAC are DSD 64, DSD 128 and DSD 256.
@Mark_Dubovoy, are you using the streamer (Ethernet) input to the Select DAC? If so, this input appears limited to DSD 256 (4x DSD) per MSB’s specifications:
DSD 512 appears to be available only on the USB interface using a PC (not the Nucleus Plus) per MSB:
The documentation specifies that the supported formats are input dependent. I could not find a document which listed the supported formats per input. If you don’t know for sure, then I would contact MSB.
Wait, I just did and MSB tech support’s reply is …
The only input that supports 8xDSD is our ProUSB interface.
The Network Renderer is limited to 4xDSD playback.
So network is limited to 4x DSD and you need to use the ProUSB interface for 8xUSB.
This is a bummer because USB is consistently and by far the worst connection one can have in terms of audio quality. Network connection is the best, AES/EBU is second best, SPDIF is third and USB is the worst.
I also checked this morning with some very knowledgeable audiophiles as well as top executives in ultra high end audio manufacturing companies and the consensus is that the USB connection is to be avoided. One is much better off downsampling the files and using the network connection.
So I will continue to use the network port and downsample when needed.
Thank you for your quick response and all your help looking into this. Highly appreciated!
