Roon Server Machine
Nucleus Plus
Hi,
I have a Nucleus Plus and just one end point. The system was working then had to reboot everything for an unrelated reason.
Since then Nucleus+ is not detectable - I note it is powering off every few minutes and then on - in regular intervals.
It feels like it’s rebooting but i don’t know why.
While this happens:
- Nothing is displayed on the screen (HDMI either A or B out) - ie no boot up text during restart nor final state showing IP address etc.
- It is not claiming an IP address from the DHCP server (checked dhcp client list on router).
I wondered if it was a network issue and first tried different cables, different port on router and even a different router (with DHCP)
I tired a direct connection from computer to Nucleus+ using a manual IP on the computer with the same subnet as was last working - this shows the Nucleus+ is on the network for a while the power is on BUT it is without an IP (by nmap scan) then it disappears as the Nucleus+ reboots - and repeats
With attached keyboard I tried the Roon network reset sequence Enter resetnetwork Enter (albeit blind as nothing shows on the screen - but done at many different timings)
I am at a loss.
Is the Nucleus+ dead?
