I can pull the logs from my side. If you could provide dates and time examples for both the Cary failing to be recognized and the degradation of audio, I’ll be able to further investigate.
I pulled logs for your case (and thank you for providing the instance dates/times!)
When I did, here is what I found.
08/04 08:08:47 Trace: [Cary DMS-550] [Enhanced, 24/192 QOBUZ FLAC => 32/192] [PLAYING @ 0:01/2:50] For Once in My Life - Stevie Wonder
08/04 08:08:47 Debug: [prebuffer] sleeping in read -- this isn't good
08/04 08:08:48 Debug: [prebuffer] sleeping in read -- this isn't good
08/04 08:08:49 Debug: [prebuffer] sleeping in read -- this isn't good
08/04 08:08:50 Debug: [prebuffer] sleeping in read -- this isn't good
08/04 08:08:50 Warn: FTMSI-B-OE qo/006E1735: poor connection kbps:5200.0 (min:7538.0)
Can you tell me how your Cary DMS-550 is connected to your network? At a glance, it’s very likely a slow networking connection that’s the culprit here.
Please let me know. I’ll be monitoring our thread.
It’s a wireless connection from my PC (Roon core) to the DMS-550. According to the WiFi router, it’s a strong connection at 5GHz. It’s a new WiFi6 router that has very good specs.
Can you rig up a (even temporary) ethernet cable and see if that helps.
WiFi is notorious (with Roon) for causing issues like you are reporting !! You will see on the forum any number of “skipping” complaints etc caused by WiFi interference and the like
Logging definitely shows a connectivity issue. If you could do as @Mike_O_Neill suggested it will tell us a bit more about what might be going on. Is it possible your modem is a modem/router combo? If so, one of these that isn’t in bridge mode could be a serious culprit for interference on both 2.4 and 5ghz bands.
Without knowing the results of a temporary LAN connection I might also ask about the distance from the router and what if any devices in between the two could be causing interference.
Please keep me posted. I’m monitoring our thread all week!
Nope. It’s just a Wifi router. I have a separate cable modem. It’s about 12-15 ft between my PC and the Cary DMS-550 and no obstructions. I don’t have a CAT 5/5e cable that long. No skipping today so it’s intermittent. I guess I’ll have to live with it. What about the failure to recognize the Cary when the app opens? Didn’t do it today, but I did note when it did happen recently. Is that also a connectivity issue?
WRT the recognition issue (I suspect there are 2 issues Recognition and Connection) is your DAC switched on when you start up Roon. Some devices need to “broadcast” to Roon as Roon starts. There are many examples on the forum. If its powered off or asleep it may not do that
