Magenta AT? - I’m not a network admin
Wifi > MacBook Pro M1 > USB > Chord Hugo2
Wifi > Chord 1go/2yu > USB > MScaler > double BNC > Chord HugoTT
2.592
All the issues below are on/off issues and appear in 20%-30 of all interactions with Qobuz. As a result, there is simply no usage of Roon with Qobuz without running into errors anymore.
For several months now.
Qobuz titles do not start playing via Roon. Sometimes with an error message, sometimes without.
On the Qobuz app in the same network on the same device, they start without any issues.
Qobuz album page does not load - Sometimes with an error message, sometimes without.
On the Qobuz app in the same network on the same device, they load without any issues.
Adding a Qobuz album to the library does not work in 20% of all attempts. Sometimes with an error message, sometimes without.
For example, sometimes you try to add Qobuz album A up to 5 times and more often, and it does not work, but you can add Qobuz album B without a problem. Then you try A again, and it does not work.
New issue.
When adding a Qobuz album to the library, other albums of the same artist disappear from the library.
I had three Bill Evens albums in my library. Then I tried to add another album to the library. It took several attempts to make this happen, and when album A finally got added, the other three albums from Bill Evens in my library were gone.
It’s getting worse for several months now, and there is no proper fix to solve the problems.
A huge part of my Roon experience is starring at these:
And NO, forcing us to do network forensic and complicated workarounds is NOT A SOLVED PROBLEM. Also, letting us search for workarounds instead of communicating the known issues pro-active is NOT a solution. No updates and no bug fixes for weeks/months is NOT a solution.
Of course, I understand that software always comes with bugs. I also understand that there is a dependency on Qobuz. But without giving us proper support and solutions, you’re just pushing your problems towards us. This is NOT ok.
That there is no flawless usage with Roon and Qobuz for many users is a known issue. However, there are no proper fixes, and there is no active communication.
- Inform your customers in your newsletter that there are possible issues with Qobuz and that there is no fix at the moment.
- Offer your customers a price reduction because you can’t provide a stable Qobuz service as advertised at the moment.
- Warn new customers on your website about the possible issues with Qobuz so that they can decide if they want to run into these problems
- Fix the problems.
