Acer windows 11
Xfinity router Ethernet
Cambridge CXNv2 wired
186,000
Roon radio does not start automatically after album ends. I have to hit play to start what’s in the queue. And then sometimes it repeats from beginning of queue.
I am having the same issue with Roon Radio
I got it to work. On my core I toggled the Roon Radio switch off then on. I hope it continues to work!
Maybe Roon should look into this!
Why isn’t support answering?
If you find a way to recreate this issue on every platform let me know… I’d pay good money to not have Roon Radio ever start again
RBO
March 25, 2022, 9:43pm
8
There are several threads on here about radio being “temperamental”.
As a starter, I would suggest your reboot your core and remotes and see it this sorts it out. You would be surprised
Support are not active during weekends and you will most likely not hear from them until Monday.
Try the restart, have a read through the others posts reporting similar issues and let’s see what others may reply to you on here.
It started to work again out of nowhere. This is very strange.
Kim
(Kimmo Suominen)
March 28, 2022, 8:04am
10
I had the same problem for the past 3-4 days, but didn’t at first recognise the issue due to queuing up long playlists.
Workaround: Reboot (*sigh* )
Intel NUC (NUC5i7RYB)
16GB RAM
Samsung SSD 850 (500 GB)
Debian 11.3
Wired Ethernet
Currently listening on a remote site over WireGuard VPN
Internet: 1000Mbps/100Mbps on both sites
Squeezebox Classic (Squeezebox3) ← on remote site (works over routing)
Cambridge Audio Evo 150
KEF LS50 Wireless II
Bluesound NODE 2i (over Wi-Fi)
It’s working on and off now
