I’m uploading Pink Floyd Dark Side of the Moon album to my external SSD connected to Intel NUC running Roon ROCK.
Album version is CP35-3017 to be exact. It is properly tagged with covers and everything. When uploaded Roon app shows it as Acapella version from 2006 with completely different cover than I have in files metadata and as cover.jpg in folder.
Why does Roon take a completely different album as this one? How can I bypass it?
Hi - a possible quick fix is this. On the page for the album, select the three dots, then ‘edit’, then ‘identify album’, and see if you can find the correct version there.
There are many things that are not available on the phone version, mostly for space reasons. Most of the desktop functionality exists on tablets (iPad and Android), but there are some small gaps as well (which can be quite annoying when one uses a large tablet with keyboard, having the same size as a small laptop). Feature requests to fill them exist
