Roon Optimized Core Kit 1.7 build 710 stable 64 bit
Router ASUS RT-AX88U
USB DAC Antelope Audio ZODIAC GOLD + VOLTICUS
Roon remote version all 1.7 after installation on tablet ( OVERMAX QUAL CORE 1026 3G) does not work. After launching Roon Remote - “Unfortunately, Roon has stopped”
Version 1.6 installation starts ok. However, this version is not compatible with my Roon Rock.
Android version - 6.0
The latest software version is installed on the tablet. I also contacted the service. I reinstalled the android on the table. Many attempts to reinstall Roon Remote of all 1.7 versions. By the way, I am an IT specialist by profession. Unfortunately, I cannot solve the problem.
