Windows 10, Core i7-12700, 64gb ram, lots of hdd space
tp link AX50 wired/wifi …remote on wifi connection through Google Pixel 6. Not using a VPN, The PC is on a wired connnection directly to the router.
Cocktail Time N50, Sonos Beam, Node 2i
11,000
The android roon remote app will not connect to the core. Roon Ark does connect and works fine on the same network. Windows firewalls are turned off. Roon is configured to allow remote access. There used to be a place on the app where I could put in my ipv4 network, but I cannot find that. I did confirm all firewalls off and rebooted phone and computer
