I have Roon running on a Intel NUC. The app works find on both iOS and macOS, with one exception. With regard to the macOS app version, the Settings | Audio page flickers at a rate that it’s near impossible to read. Oddly enough, it’s the only page that flickers. I’ve tried rebooting the NUC as well as the network with no success with regard to eliminating the flicker. I’ve also tried deleting/reinstalling the app — also no success. I’ve had Roon operating functionally for years and this flicker issue seems to be relatively new (I can’t be sure when it exactly started).
On macOS, in your home directory, there is a hidden file called .rmembid - It’s where all of your Audio zone information is stored. You can see it in the Finder if you show hidden files with Command-Shift-.
Quit Roon, delete that file, then restart Roon. See if that helps.
I am also experiencing this strange behaviour! My server is a Intel Nuc but i have Roon installed on two macs, One M1 Pro 13", where everything is fine and a M3 pro 15" where the flickering takes place on the audio settings screen. When i hold the edge of the screen, it stops, resizing does not stop the flickering and it is very annoying!!!
For anyone still struggling with issue, it was resolved today with the latest macOS Tahoe 26.5.2. I was also struggling with why my Macbook Pro wasn’t appearing as an endpoint and found I had change firewall settings to allow connections from Roon and RAATServer.
