Roon is located on my SonicTransporter i5 and it is running version 1.8. The Sonic Transporter is running version 2.8 of its operating system
Orbiter router running into an EtherRegen ethernet switch
The SonicTransporter is connected to an OpticalRendu which in turn is connected to an ifi Pro iDSD DAC.
100,207 tracks
When the system plays a track that is located on my hard drive (but not on Tidal or Qobuz), it will randomly skip to the next track at some point before finishing the previous track It will pause for a second or two and then skip to the beginning of the next track, and do it again When it pauses, it shows the following message:
âAn audio file is loading slowly. This may indicate a performance or hardware problem.â
From that description, I canât tell if the problem is in the hard drive, corrupt music files, my SonicTransporter, Roon software, or something else I dont understand. Help, someone who is more technically proficient than I am.
I think here we donât get much further without good technical guidance from the team or a few really very knowledgeable helpers in the community. Surely there is a small queue until a Roon staff member can take care of it.
Depending on the level of computer literacy, some in the community also try to understand your LOG data themselves and look for errors, warnings, etc. in the logs for first better clues.
Thanks for responding. Do you know of anyone in the community that might be a good technical person to look at my log data or anything else that might jumpstart figuring out the source of this problem? Thanks, Uwe. And of course, Roon staff will eventually respond as well.
I have a question for someone. When I copied my music hard drive (which was starting to fail) from one hard drive to another (both hard drives were poweredâhad their own power supplies), I used a non-powered USB-C hub connected to my 2018 MacBook Pro. Iâm wondering if I should have used a hub that was powered, one with its own power supply. I ask that question because both hard drives were ejected by the computer erroneouslyâI didnât initiate the ejection. It happened several times. Iâm wondering if this indicates that I needed to use a powered hub for the copying to be successful. And, could it also mean that the files got corrupted due to the hard drives being ejected mistakenly several times.? Anybody have any thoughts or suggestions?
I expect someone from Staff may take care of your problem and both (yours and mine) get solved quickly
BTW no changes at all from day previous yesterday to yesterday. No new music added, no change of HD, no new stuff (players) added⌠simply skipping files
It seems to be a common problem. I have an audiophile friend who lives in Tacoma so itâs not an isolated issue. Do you have any thoughts (no matter how outrageous) about whatâs causing this? Iâll work with anything, even âaliens have decided they donât like Roon and theyâre just messing with us.â Well, ok, I wonât go for that explanation.
This is a massively common problem. I have it as well. Is there any option I can change to make roon less sensitive to loading tracks? I would significantly rather have my track pause for a second and finish playing than just have an infinite skip loop when my internet is vaguely slow. better yet, I dont give a single care about my memory usage, is there any way to just buffer the entire song before it ever plays? This issue is so annoying its literally making me not use roon for my listening recently
My educated guess (out from Alienâs scope, as far as I know about them) is related to have music on a NAS and the NAS under PLC connectivity, which means 10/100 but Roon is comfortably installed onto a i3 machine with 8Gb RAM and a beautiful 10/100/1000 net connection.
As a first step Iâd suggest simplifying your network, i.e. remove the EtherRegen and OpticalRendu and just use Cat 5 or Cat 6 ethernet cables. At this stage - i.e. before support weigh in - I think it makes sense to eliminate some of the possible causes. By swapping out the EtherRegen and OpticalRendu we can rule out (or make a move towards ruling out) your network as a possible cause of this problem.
From reading these threads for a few years the cause of âfiles loading slowlyâ is nearly always network related. Roon requires a robust network to operate properly and, even when other programs are working well, Roon may stumble if your network isnât solid.
Thanks for your reply Dave. Iâm happy to try your suggestion, but I have a preliminary problem. The network doesnât recognize the music hard drive now, so I canât do anything until that problem is fixed. Itâs weird. My server (SonicTransporter i5) clearly recognizes the hard drive attached to it, but the network does not. Without that step, I canât get Roon to notice and scan the contents of the hard drive. Any thoughts about how to fix that problem?
I donât know much about the SonicTransporters, but why do you need to identify the hard drive over the network? If the ST is running Roon, isnât the hard drive locally attached? On my Mac, I can add local folders and network shares. What are you seeing in the Storage tab in settings?
I did that and it initially created a new version of the old folder with close to 80,000 tracks. When I tried to play something on the hard drive, it reacted with a message that essentially said it cant play the track because itâs loading too slowly. Then I noticed that the 80,00 track number started to decrease on its own and its down to zero tracks now. Not sure how to identify the exact name of the folder the music is in and get it to rescan those files
In which case, unless anyone else has any good ideas, I think youâll need to wait for @support to take a look and see if they can work this out for you.
