Roon Streaming Tidal Issues: Hi-Res Audio Downsampling to 44.1kHz on Denon X6700H (ref#9RJOW4)
· Something else
Hi,
I need a few support questions answered. I'm new with Roon / Tidal. I implemented my Roon server streaming Tidal. I prior updated my firmware on my Denon X6700H streaming AirPlay2 from the Roon Signal Path. I read all the tech notes on your site with these current / recent updates that were lacking some months back until now.
That said, I am Connected playing Hi-Res music. Question, why do I see my SOURCE begin with FLAC 96KHZ 24bit at the end it converts down to 44.1Khz 16bit into my Denon????
TIA,
-Dino Lauricella
Hi,
TIA,
-Dino Lauricella
Because you’re using Airplay.
Hi @dlbello,
The conversion and downsampling you’re referring to is a consequence of Airplay and is outside of Roon’s control. Airplay caps the quality of the audio stream; consider it a philosophical networking bargain for convenience and ease-of-use.
You can read more here.
