During the latest weeks ROON is no any longer able to control the volume to my PS AUDIO PerfectWave DirectStream DAC, any ideas on what can be wrong?
Hi @Juan_Cifuentes,
Is there any change in behavior if you reboot your Core + PS Audio DAC (power off, unplug, wait 30 seconds, plug in, power back on)?
Yes, that help temporarily until it stops again.
Although I normally prefer to reboot the DAC since it simpler but rebooting the core helps as well
Hi @Juan_Cifuentes,
Thanks for confirming that the reboot helps temporarily.
What does your Device Setup page look like for this zone, can you please share a screenshot?
Hi @Juan_Cifuentes,
Thanks for that screenshot, this looks as expected to me.
When you say you are no longer able to control the volume - can you be a bit more specific as to the exact behavior? Are you able to press the + / - in the app and that changes the volume in the app but not on the device itself? Or does pressing the + / - buttons trigger no change in behavior and volume remains at 50?
Next time you run into this behavior, please note the exact local time + date + track affected and we can look into diagnostics.
Ok thanks!
I will note the info next time, currently is stable and works
