Win 10 PC latest build
**Network Details (Including networking gear model/manufacturer and if on WiFi/Eth
Wired Ethernet to PC core and MiniDSP SHD
SHD coax SPDIF to amp
Hi, I use Roon exclusively to select music. Roon has a volume slider and can be toggled between Fixed and Device. In Device, Roon sends the full-strength music signal along with volume instructions (according to Roon). That said, I have set Roon to Device volume but the slider has no control over the volume that is heard nor the volume number displayed on the SHD. Is there a setting somewhere I missed? (I’ll post this in MiniDSP forum too, not sure which side is the issue.)
