Hello, lately (probably somewhere around Roon release when RAAT was switched from UDP to TCP?) i am occasionally getting 1-3 second dropouts on beginning of the track (be it local or tidal).
HW and NW should be fine i believe (Roon running on i7 NUC with Linux and dedicated NW interface for the Bridge2 - connected via TP-Link optical transceivers).
I did not have this issue before (there was Roon release and new Bridge2 firmware release around the same time when it started to appear - so i guess the guilty would be one of those two…).
Here is the log + interface stats taken after I got another short dropout today:
08/19 11:02:24 Trace: [zoneplayer/raat] Endpoint PS Audio DirectStream DAC State Changed: Playing => Prepared
08/19 11:02:24 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] SENT [9445]{"request":"end_stream"}
08/19 11:02:24 Debug: Lastfm 'ac86c2e5504f0240c7c0b565650cf441' DONE: Wham! - Heartbeat
08/19 11:02:24 Info: [library] recorded play for profile 6b1d9a0c-e7d0-421c-8c07-18e015e342c6: mediaid=50:1:8a4668ff-092d-4c1f-bc8f-62bc886088a4 metadataid=123:0:MT00091858
08/19 11:02:24 Trace: [library] finished with 8 dirty tracks 1 dirty albums 8 dirty performers 8 dirty works 8 dirty performances 0 clumping tracks, 0 clumping auxfiles 0 c
08/19 11:02:24 Debug: [library/index] updating search indices: 8 ops 0 adds, 0 removes
08/19 11:02:24 Trace: [library] endmutation in 25ms
08/19 11:02:24 Info: [zoneplayer/base] Playing: /music/__TORQ-FLAC-VA/Greatest 1980s music hit singles/Wham! - I'm Your Man.flac
08/19 11:02:24 Info: [audio/env] [zoneplayer -> stream] All streams were disposed
08/19 11:02:24 Debug: [raat/tcpaudiosource] disconnecting
08/19 11:02:24 Info: [audio/env] [zoneplayer -> stream -> endpoint] All streams were disposed
08/19 11:02:24 Info: [audio/env] [zoneplayer] All streams were disposed
08/19 11:02:24 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] SENT [9447]{"request":"update_artwork","mimetype":"image/jpeg"}
08/19 11:02:24 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9160] {"status":"Ended"}
08/19 11:02:24 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9445] {"status":"Success"}
08/19 11:02:24 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9447] {"status":"Success"}
08/19 11:02:24 Info: sleep 160ms after flush
08/19 11:02:24 Info: [zoneplayer/base] Queueing: /music/Wham!/1984 Make It Big (2001 Remastered Japan Edition SACD) [16@44]/05 Freedom.flac
08/19 11:02:24 Info: [zoneplayer/base] Open Result (Playing):Result[Status=Success]
08/19 11:02:24 Info: [zoneplayer/base] Starting playback
08/19 11:02:24 Trace: [zoneplayer/raat] StartStream Sooloos.Broker.Transport.RaatZonePlayer+Endpoint: StreamFormat(channels=2, bitspersample=16, samplerate=44100, isdts=Fal
08/19 11:02:24 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] SENT [9450]{"request":"teardown"}
08/19 11:02:24 Trace: [zoneplayer/raat] Endpoint PS Audio DirectStream DAC State Changed: Prepared => Idle
08/19 11:02:24 Info: SETUP FORMAT StreamFormat(channels=2, bitspersample=16, samplerate=44100, isdts=False)
08/19 11:02:24 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] SENT [9451]{"request":"setup","format":{"sample_type":"pcm","sample_rate":441
--[ SignalPath ]---------------------------------------------
SignalPath Quality = Lossless
Elements:
Source Format=Flac 44100/16/2 BitRate=995 Quality=Lossless
Raat Device=PS Audio DirectStream DAC
Output OutputType=Local_Analog Quality=Lossless
08/19 11:02:24 Debug: Lastfm 'ac86c2e5504f0240c7c0b565650cf441' START: Wham! - I'm Your Man [1986 short version 3_01]
08/19 11:02:24 Trace: [prebuffer] ready 149940/441000 (34%) @ 0/246 sec
08/19 11:02:24 Info: [zoneplayer/base] Open result (Queueing): Result[Status=Success]
08/19 11:02:24 Trace: [prebuffer] ready 299880/882000 (34%) @ 0/301 sec
08/19 11:02:25 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9157] {"status":"Teardown"}
08/19 11:02:25 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9451] {"message":{"signal_path":[{"method":"analog","type":"output","qua
08/19 11:02:25 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9451] {"audio_port":0,"status":"Success","audio_port_tcp":47335,"clock_p
08/19 11:02:25 Trace: [zoneplayer/raat] Endpoint PS Audio DirectStream DAC State Changed: Idle => Prepared
08/19 11:02:25 Trace: [zoneplayer/raat] synced to endpoint clock. realtime=48524176947168 rtt=673us offset=26802775084us delta=26802775084us
08/19 11:02:25 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] SENT [9453]{"request":"stream","stream_id":953748709,"first_seq":-1,"nak_port
08/19 11:02:25 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9453] {"status":"Buffering"}
08/19 11:02:25 Trace: [zoneplayer/raat] Endpoint PS Audio DirectStream DAC State Changed: Prepared => Buffering
08/19 11:02:25 Trace: [zoneplayer/raat] [zoneplayer/raat] selected PS Audio DirectStream DAC as clock master
08/19 11:02:25 Trace: [prebuffer] status 441000/441000 (100%) @ 0/246 sec
08/19 11:02:25 Debug: [raat/tcpaudiosource] connecting to 192.168.52.52:47335
08/19 11:02:25 Debug: [raat/tcpaudiosource] connected
08/19 11:02:25 Warn: [raat/tcpaudiosource] send failed: unexpected partial write
08/19 11:02:25 Warn: [raat/tcpaudiosource] disconnecting + retrying
08/19 11:02:25 Debug: [raat/tcpaudiosource] disconnecting
08/19 11:02:32 Info: [stats] 6243mb Virtual, 2297mb Physical, 679mb Managed, 0 Handles, 71 Threads
08/19 11:02:35 Warn: [zoneplayer/raat] Endpoint failed to become ready in 10s. Proceeding in state Buffering
08/19 11:02:35 Trace: [zoneplayer/raat] Endpoint PS Audio DirectStream DAC State Changed: Buffering => Ready
08/19 11:02:35 Trace: [zoneplayer/raat] wait for ready in 10000ms
08/19 11:02:35 Trace: [zoneplayer/raat] Adjusting playback start offset from 50ms to 180ms
08/19 11:02:35 Trace: [zoneplayer/raat] Starting at streamsample 0 and time 48534276936168 min_offset=180ms offset=180ms
08/19 11:02:35 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] SENT [9454]{"request":"start","time":48534437044168,"stream_sample":0}
08/19 11:02:35 Trace: [zoneplayer/raat] Endpoint PS Audio DirectStream DAC State Changed: Ready => Playing
08/19 11:02:35 Trace: [prebuffer] status 441000/441000 (100%) @ 2/246 sec
08/19 11:02:35 Debug: [raat/tcpaudiosource] connecting to 192.168.52.52:47335
08/19 11:02:35 Debug: [raat/tcpaudiosource] connected
08/19 11:02:35 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9453] {"status":"Playing"}
08/19 11:02:35 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9454] {"status":"Success"}
08/19 11:02:35 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9453] {"samples":10870,"status":"Dropout"}
08/19 11:02:36 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9453] {"samples":21168,"status":"Dropout"}
08/19 11:02:37 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9453] {"samples":21168,"status":"Dropout"}
08/19 11:02:38 Trace: [transport/raatclient] [PS Audio DirectStream DAC @ 192.168.52.52:49993] GOT [9453] {"samples":9458,"status":"Dropout"}
08/19 11:02:40 Trace: [prebuffer] status 441000/441000 (100%) @ 8/246 sec
08/19 11:02:45 Trace: [prebuffer] status 441000/441000 (100%) @ 13/246 sec
08/19 11:02:47 Info: [stats] 6243mb Virtual, 2298mb Physical, 679mb Managed, 0 Handles, 63 Threads
08/19 11:02:50 Trace: [prebuffer] status 441000/441000 (100%) @ 18/246 sec
08/19 11:02:55 Trace: [zoneplayer/raat] sync PS Audio DirectStream DAC: realtime=48554435207569 rtt=606us offset=26802775054us delta=113us drift=-29us in 30.258436s (-0.978
08/19 11:02:55 Trace: [prebuffer] status 441000/441000 (100%) @ 23/246 sec
08/19 11:03:00 Trace: [prebuffer] status 441000/441000 (100%) @ 28/246 sec
08/19 11:03:02 Info: [stats] 6243mb Virtual, 2298mb Physical, 679mb Managed, 0 Handles, 63 Threads
08/19 11:03:06 Trace: [prebuffer] status 441000/441000 (100%) @ 33/246 sec
08/19 11:03:11 Trace: [prebuffer] status 441000/441000 (100%) @ 38/246 sec
08/19 11:03:16 Trace: [prebuffer] status 441000/441000 (100%) @ 43/246 sec
08/19 11:03:17 Info: [stats] 6243mb Virtual, 2298mb Physical, 680mb Managed, 0 Handles, 63 Threads
08/19 11:03:21 Trace: [prebuffer] status 441000/441000 (100%) @ 48/246 sec
08/19 11:03:25 Trace: [zoneplayer/raat] sync PS Audio DirectStream DAC: realtime=48584643344836 rtt=1629us offset=26802771995us delta=-3199us drift=-3088us in 60.469701s (-
08/19 11:03:26 Trace: [prebuffer] status 441000/441000 (100%) @ 53/246 sec
08/19 11:03:31 Trace: [prebuffer] status 441000/441000 (100%) @ 59/246 sec
mii-tool eth3
eth3: negotiated 100baseTx-FD, link ok
ifconfig eth3
eth3 Link encap:Ethernet HWaddr e8:80:2e:e7:39:05
inet addr:192.168.52.1 Bcast:192.168.52.255 Mask:255.255.255.0
inet6 addr: fe80::ea80:2eff:fee7:3905/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:16166142 errors:0 dropped:0 overruns:0 frame:0
TX packets:43678372 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1159546512 (1.1 GB) TX bytes:59236307286 (59.2 GB)
Many thanks!
