Set volume per track
Is there any way you can set a default volume individually for each track. Imagine a carefully assembled playlist featuring totally different genres. Volume levelling is definitely not what I want.
Go to device settings, volume levelling, and select ā€œTrackā€.
  1. Track - Performs adjustments on a track-by-track basis. This produces the most consistent volume level during a playback session, but may result in unpleasant jumps in volume during playback of a gapless album.
As I said ā€˜Volume Leveling’ isn’t what I’m after. An orchestra is much louder than a guitar. A Piano is louder than a flute. I want to set a realistic volume for each - individually.
No there isn’t. You may add it as a feedback, feature suggestion.
You could add this potentially to this feature request that is closely related and vote for it…
Yes, volume is the same as flat EQ down/up
The volume is very important. When a HiFi starts sounding like the real thing, the volume is very important
