Innuos Zen, 2TB + Chord Hugo II
No network involved. Music is played from the internal disk on the Zen.
Chord Hugo II directly connected via USB (Audioquest Cinnamon) and using the Innuos setup as Roon Core with Squeezelite Player.
When using my Roon software, the track skips to the next within the first 5-10 seconds and the timer then stops at 0:00.
When clicked enough times on the play button of the first track it ends up playing correctly.
This only happens when using USB direct with Hugo. All other network devices (Bang & Olufsen and Sonos) works fine.
I have just been in contact with Innuos and they have explained that it is because this special Roon setting is still in beta.
They have also given me documentation for a workaround, so this I will try later this week (I’m out of the country right now). I’ll get back to you should this not work.
Consider this “ticket” closed and thank you for helping me out
