i7 12700KF’s Windows 11 PC
32GB RAM DDR5 4800
Ethernet and Roon ARC with WiFi or 5G
Roon ARC
3000 tracks
I have a DAC that made by my friend could work with ARC since we get it on iOS, and everything work very well and didn’t have anything wrong.
But when I try it with Android Roon ARC with BETA USB drive, the problem is be like: When I play a song with simple rate 48Khz, and I change to another song that simple rate is 96 Khz, the DAC still show that the simple rate now is 48Khz, won’t show as 96 Khz and this made sound become very weird and not accurate.
But Android’s one work with my Mojo1 very accurate, simple rate change and the problem didn’t there, of course the DSD will convert to PCM but it’s not so important this moment.
But it work very well with iOS, so I think it should be kind of problem with Android USB drive?
I do not know how can I help you with, if need any information just reply me plz!
