Thank you for confirming @noris!
Meanwhile, I’ve changed Qobuz inside Settings > Services to only play CD-quality.
Hello @VOBOSHI,
Thanks for your patience while we investigated this report. We can confirm that the “Use Max Hardware Buffer Size” option in Roon will result in different ASIO buffer sizes depending on the sample rate of the audio.
We’re going to follow up with the development this week to confirm that this is the expected behavior.
-John
