Sound distortion issue when using Roon with Auralic Aries G1 and MacBook Pro (ref#36QHJA)
Full form submission
I'm having trouble playing music
Significant lag after pressing play
Im trying roon with my Auralic Aries G1 and using a MacBook Pro as roon core, connected via Ethernet, as are the Aries.
Sometimes, not always, when im shifting songs or when roon is shifting album im getting digital lagging, the sound gets scrambled. I can fix this by pressing paus and then play again. but why do this appear? Is there some settings that shoul be made in roon or lightning DS?
Hi @Felix_Gerlach,
Can you please share a screenshot of the Signal Path in Roon when you’re streaming back music through the Aries? This will be the popup window when you click on the illuminated dot next to the playback bar.
Additionally, can you please share the name of a track that was playing when you last encountered this?
In the meantime, I recommend adjusting the Resync Delay in Settings → Audio → Device setup for the affected Zone. This will give the stream more time to adjust if it’s rapidly switching between tracks of different formats and sample rates.
