Macbook Pro 2.4 Ghz Intel Core 2 Duo / Memory 4 GB 667 MHz / Running 10.10.5 / Latest Roon Build
Ethernet Gig Switch
Meridian MC200 Endpoint / Copland Amplifier
I initially tested Roon Core using my newer Macbook running 10.15.4 streaming to MC200. The sound quality seemed slightly better than on older laptop. Also, DSP worked better on newer Mac. DSP on older CPU tends to sound distorted. Does the CPU affect the sound quality and DSP capabilities?
