Zenith Mk.3
Music Server Online
Serial Number: 1903000011351
Powered by innuOS version 1.4.7
Roon 1.7 build 710
Xfinity XFi cable internet. Most recently measure at 481 mbps down and 23 mbps up.
XFi modem etherneted to Eero Pro Wifi 6 router. Several other Eero Pro 6 Wifi mesh network routers on network. One of these in my listening room is either Etherneted to an SOtM sNH-10G hifi network switch. Innuos Zenith Mk3 is also Etherneted to this switch. Zenith Mk3 houses the Roon core above with Squeezelite Player. USB cable out from the Zenith to Innuos Phoenix USB reclocker. USB out from reclocker goes to USB in on DAC that is normally played in Roon as the Squeezebox device.
Per above.
In Roon > Audio I normally see Squeezebox as one of the available devices. However, now I am seeing a message which says “Searching for Squeezebox devices. If you don’t see your Squeezebox devices here, make sure that LMS is turned off”. However:
- How do I turn off LMS and where do I turn it off?
I have tried turning off Roon on my Zenith rebooting it and turning it back on. I have disabled Squeezebox Support in Roon > Settings. Then I turned Roon with Squeezlite and Squeezebox Support back on in the Zenith and my Roon iOS iPhone app, respectively. But it doesn’t establish Squeezebox support and eliminate the above message.
