How about:
Those are a few teasers and I suspect if you try them that ROON will find you more things to your liking! I would start with Pachelbel. Which you will likely recognize! Then maybe the Chorus of the Slaves. And afterward Carmina Burana and/or Mozart’s Requiem. The latter are longer, with many parts. Then of course there’s Handel’s “Messiah” which you are likely familiar with, but ROON will use that to provide further classical music. Put Palestrina in and see where it takes you. Try a little Bach and listen for how the music starts out and then riffs from the beginnings. The same thing happens with Beethovan. Try “Fur Elise.” Or his Sonatas.
I recently discovered Ori and Omri Epstein (brothers who play piano and violin) and Utube has some amazing short HD recordings that you may fall in love with. From different composers. They are also part of a trio and play/record lovely music.
These ideas will get you started. Then you may find you also enjoy sacred music from either the Orthodox tradition or the Catholic monks. (Try to find recordings of actual monks for both. The Russian Orthodox Liturgy can be trance-inducing.)
Hope at his helps, Mike! And thanks for your wonderful advice and recommendations.
My plan at the moment is to wait till Monday (when the snowstorm is over) and get the cabling to hook up my Surface Laptop to download a trial of Roon, then see how much better sound I get just from an Ethernet connection (via laptop) to my MacIntosh. I can also try ripping some CDs and seeing what Roon does with them - and how that might be tweaked. Etc. Etc.
And afterwards consider which Roon machine to get. The only reason (possibly) to pay for the more powerful one, from my perspective, is that the upgraded DAC module (recently available and now installed) allows for playing music so HD that you probably can hardly it find at the moment - but that will be coming. (Of that I have no doubt.). Whether one can hear such a difference… well, that’s the question of course.
DA2 Module “Supports up to DSD512 and DXD 384kHz”
Versus DA1 Module: “DSD256 and DXD 384kHz levels”
And more differences. Not that I truly understand what those words just above mean.
So that’s why I’m wondering about the more expensive Roon. (Though could Roon upscale the less expensive model to do that in future? Or is it a hardware issue from the get-go?)
If anyone has the technical expertise, it would help me decide whether - in the long run - it’s to my advantage to have the Nucleus model that allows for greater … (whatever you call it).
While I’m 75, there is longevity in my family. So I could be looking at another 25 years of bliss here!
My compliments to you all! What a great/helpful group!
