Hi @Kenji_Hayashi, The USB issue appears to be a Bluesound problem? Should your enjoyment of Roon pay? Since BluOS doesn’t do DSD or high Rez above 192/24, try Spdif output. I was very happy with the performance.
Thanks for your suggestion, @RTaylor3rd!
Just purchased an optical cable after reading your suggestion.
Will follow up after I try it out!
Is this USB issue something that’s widely known?
For what it’s worth, I haven’t had any issues playing music streamed from Qobuz through BluOS with my setup (USB out from Bluesound Node to RME ADI-2 DAC FS). It’s just that I don’t enjoy BluOS’ interface.
same boat here, Roon Core on desktop pc win11, Node 130, remote on ipad, Denafrips Pontus 2 r2r dac. Through coax everything is fine but usb is totally worthless.
Follow-up to my earlier post: I switched from USB to Digital Coax (changed my mind about optical) and no more popping noise! Thank you for your suggestions, @RTaylor3rd and @Wes !
Looks like I’ll be purchasing a 12-mos subscription of Roon after all
