Windows 10 Pro / i5-6260 CPU / Roon Build number unknown (where can I find it?)
ZTE - H369A - WiFi
Meridian 818V3
I shut off the Roon software and returned to the original Meridian software because of the fact that this afternoon the volume of my Meridian 818 automatically went spontaneously to the maximum (and not just once). Lucky I maximised the volume at 70 in the Roon software! I was shocked and I don’t trust your software anymore.
Did the volume adjust during playback? Or was it when a track was changing? Or the first time that you selected the device during that session of using Roon?
But for your information, a couple of years ago I also tested your software and It also happend with my previous preamp, the Meridian G61R. At that moment I stopped with Roon and the reason I started again is because because Meridian doesn’t support there own software anymore (New imports don’t show album art)
Apologies for the delay here. I spoke with the team about this, and we did some testing and we were not able to reproduce behavior similar to what you’re seeing. This isn’t something we’ve seen other reports of either, so it’s hard to say exactly why you experienced this.
While there shouldn’t be an issue here moving forward, if you experience and similar behavior in the future, please make a note of the following:
The track that is playing
The time the issue occurred
With this information we can enable diagnostics and take a closer look.
