Hi @nuwriy, I assume that all is busy with the next version of Roon, but I am still getting repeated failures which I have not had for the majority of my time with Roon (since day one!). I have another failure today, 29th January at 11:19 GMT.
@support@nuwriy Iâm still having this issue with Roon 1.8 and havenât received any reply to my pervious emails. I understood that diagnostics were being collected but feel that there should be a wealth of data by now.
I love Roon, and am a fan of version 1.8, but having to restart my Roonserver on a continual basis is trying my patience. In addition, I am also continuing to lose contact with my Meridian 218 endpoint. Itâs difficult to understand if this is consistent with losing Tidal connectivity.
Please can you let me know either way whether this can be resolved. Otherwise I feel that I will need to start from fresh again and, having used Roon since day one (and Sooloos before that), that is not something I want to do.
Sincere apologies for the delay in getting back to you here. I am looking over your Roon logs and I am noticing some strange traces here that might be related to your Roon database, can you please try to see if a fresh database also reproduces this issue?
Hi @noris. After 12 days of testing this and putting quite a load on the RoonServer, the Tidal login does appear to have been resolved. However, Iâm still getting the intermittent drop outs in the zone that comprises of a Meridian 218 endpoint. I havenât had dropouts in any other zones, Meridian or otherwise, although they are not used as much as the 218 zone. Any thoughts?
Finally, is there any way that I can extract any of the work that I did on my previous library or have I now lost that? Favourites, playlists, even listening history?
Does this behavior affect both Local and Streaming / Live Radio content or just one type and not the other?
Do other zones such as the System Output on your Mac Mini exhibit the same behavior?
Unfortunately, extracting pieces of your database are not possible, you would have to revert to a Roon Backup that does not exhibit this issue. If you donât have a backup before the issues started to occur, then continuing with a fresh database is the best path forward.
