Roon with ROCK (Linux ALSA) on my Nuc i7.
DAC SMSL M400
Hello, I am using Tidal MQA, but in Signal Path it only shows me ENHANCED, not LOSSLESS?
Carl
2
Hello @Claudio_Silva,
I suspect all is fine, however, can you upload a screenshot of the Roon Signal Path so it can be checked.
RBO
4
That is absolutely fine. Roon is reporting that your DAC is performing the MQA decoding and rendering and this is why it shows as “Enhanced”.
What would be the correct way?
Jim_F
6
Because Tidal MQA is not lossless when it’s being upsampled from 44.1 or 48 to it’s “unfolded” resolution of 88.2 or 96 or higher.
This means that Enhanced is better than Lossless
RBO
10
Not entirely correct Jim. Signal path can be Lossless with MQA. See mine for example.
Jim_F
11
Well yes, of course, it’s not being upsampled. It’s a 44.1 MQA file.
RBO
12
My bad Jim. Misread your post.
Jim_F
13
No, you were right. I corrected my post.
system
(system)
Closed
14
