Tidal does not show up in my Roon system and it always has. When i try to login to Tidal through Settings/Services/ it says “bad username or password”. However, i can log in directly into Tidal with my password/username and get in just fine. I was using tidal as late as last week without problem. What do think i am doing wrong? Thank you.
Have you made sure to place your full login on the Settings/Services tab? This would include your email address at the end as well. Can you verify if the same login works on the TIDAL web player (listen.tidal.com)?
I was able to login to listen.tidal.com with my username and password. You say full login on Roon—i go to Settings/Services/Tidal then click on login and enter my username(my email address) and password. It still comes up “bad username or password). When i am on the Settings/Services page, it does say next to Tidal “not configured”. Not sure that matters.
