Ernie
(Ernie)
November 22, 2019, 2:24pm
1
Imac
Ethernet
Topping d10 usb
Track advances prematurely sometimes. Issue is also described by some on the audiophilestyle forum
Ernie
(Ernie)
November 22, 2019, 3:00pm
2
Continuing to experience some of this today. I neglected to mention that I am outputting to hqplayer. Maybe that is where the hiccup is? No others experiencing this?
With that lack of details it will be hard. For anyone to help.
Ernie
(Ernie)
November 22, 2019, 3:07pm
4
Not sure what you mean but here is another try. When steaming via qobuz it will often advance to the next track before the current one ends. New since 1.7. Imac to hqplayer to D10 to outlaw amp, is the setup. Similar comments on the audiophilestyle forum.
**Core Machine (Operating system/System info/Roon build number)
Audio Devices (Specify what device you’re using and its connection type - USB/HDMI/etc.
Ernie
(Ernie)
November 22, 2019, 3:12pm
7
Gave all of that except for the modem…MG7550, motorola. Always been the same setup, just 1.7 is new.
dylan
(Dylan Caudill)
November 22, 2019, 3:16pm
10
Hi @Ernie ,
Is the Motorola modem the only networking device in use? No switches or anything else? What are your download speeds?
Does the same behavior occur if you are not using HQPlayer or you play to a different endpoint?
Ernie
(Ernie)
November 22, 2019, 3:19pm
11
No switches. Download 100 mps. I will see if removing hqplayer from the chain helps and get back to you.
Ernie
(Ernie)
November 22, 2019, 3:17pm
12
Similar problem here.
Imac using 1.7 to hqplayer to topping dac to outlaw amp. Problem is new since updating to 1.7
Ernie
(Ernie)
November 22, 2019, 3:28pm
13
Looks like you don’t have hqplayer in your chain, so probably is not that.
Ernie
(Ernie)
November 22, 2019, 3:45pm
14
Just occurred without hqplayer in the chain
Ernie
(Ernie)
November 22, 2019, 7:13pm
15
Still occurring for me as well. Not that often but regularly…impossible to listen to a complete piece
Ernie
(Ernie)
November 22, 2019, 8:17pm
16
Hopefully this is something small and fixable. I had been really enjoying the improvements of 1.7. Radio is much better, and the suggestions are pretty good and sure to improve. I really want to stay with Roon.
Ernie
(Ernie)
November 22, 2019, 9:53pm
17
That didn’t take long…4:53 EST 11/22
Ernie
(Ernie)
November 22, 2019, 10:56pm
18
two times now
4:53 EST 11/22 (as noted earlier)
5:55 EST
sorry…both PM
Ernie
(Ernie)
November 23, 2019, 4:25am
19
I have experienced the problem with a locally attached dac and with system output. Also with no dsp on.
Ernie
(Ernie)
November 23, 2019, 12:38pm
20
From those of us who have already given timestamp info, do you need us to continue?
Ernie
(Ernie)
November 23, 2019, 1:03pm
21
Just occurred here at 8:02AM est
