Trouble adding Cocktail Audio X50 to Roon
Hi @Tony_Colletti,
Glad to hear you were able to get the X50 share working again with @Rugby’s help (Thanks for jumping in here Rugby!).
As for the issue of not being able to connect your iPad/Phone to Roon, I would check the Windows Firewall.
Since you are using a Windows PC, I would verify that both Roon.exe and RAATServer.exe have been added as exceptions to your Windows firewall.
You can use these instructions to add the exceptions and the executables themselves would be located in your Database Location/Application folder path.
I would also add these exceptions to any Antivirus or other Firewall blocking applications you may have and make sure that you’re using a Private network type, not a Public one, you can use these instructions to check this.
I USE VIPER. Not the Windows Firewall. I’ll make sure they’re off though. Thank you noris. I’m a massive Fan of ROON and it’s community. I’m just not good at computer Issues. wow–gpedit still makes me laugh. No Clue what that was. lol
