Thanks for taking the time to write in, and welcome to the community! Sorry to hear you’re having issues connecting to your Roon Server.
This would be the first place I’d investigate. I would make sure Roon is listed as a proper expectation in both your windows firewall as well as any additional antivirus software. You can learn more about how to do this here:
You can also test this by temporarily disabling your windows firewall and seeing if you’re able to connect.
Als ik de firewall voor het openbaar netwerk inderdaad uitzet, dan krijg ik met de remote wel verbinding met de roon-server. Welke instellingen moet ik dan doen?
