Following a power outage, I can no longer connect my Nucleus + Rev B as a Roon Server. When I reconnected, Roon offered me to choose another Roon Server by disconnecting my license from the Nécléus +. which I did. Maybe it was a mistake. So I used a backup and I find myself in the general tab with my PC as the server but when I click on Configuration the name of my server is Nucleus +. And I can no longer connect to my dap that I had in the Audio section (Topping DX7 Pro). Roon no longer offers me the choice of server and I can't connect to the Nucleus Web Administration Interface. In short, I don't know how to go back to how the situation was before. If you could help me. Thank you very much.
Bonjour Carl et merci de votre réponse.
Lorsque je branche une prise HDMI à la TV mon nucléus apparait (sous le nom de NUC Intel)
Mais la TV m’affiche " Pas de Signal". J’ai essayé deux prises HDMI différentes et j’ai le même message.
De Plus mon réseau internet ne reconnait plus le Nucléus.
Une question: Quelle est l’utilité du clavier dans cette manipulation?
When I connect a HDMI socket to the TV my NUC appears (under the name NUC Intel)
but the TV displays “No Signal”. I have tried two different HDMI sockets and I get the same message.
What’s more, my internet network no longer recognises the Nucléus.
One question: What use is the keyboard in this operation?
Hi could you clarify please … as the first statement suggests the NUC’s HDMI display is active, but then you say there is no signal.
The keyboard is not needed for this initial test, but it may have been useful for next steps (like resting NUC network settings) but with no HDMI signal the keyboard is of no help.
