Ethernet only
micro Rendu
I just got a new Line Magnetic CD 24 player with a built in DAC (USB input)… neither my micro Rendu not my Computer (used as a Roon Endpoint) sees this device.
I can, however, play audio through it directly from the computer via Tidal.
Please advise… will the DAC to work with Roon via a Roon bridge?
So currently you have it hooked up to your computer via USB? or do you have it hooked up to the microRendu with a USB cable? Either way it should work just fine with Roon. Roon won’t always display the device by its model name like “Line Magnetic CD 24” but will display something identifying the DAC that is in the unit, like is shown in your picture. It is no big deal and should still work
Wait, when you listed. the iTransporter i5 are you talking about the Sonic Transporter i5? Is that your Roon Core? If so, that is what you should hook up your Line Magnetic to if you can and see if you can get it to play from there (to test and make sure it works from Roon).
If you are hooking it up to another computer that you are using as an endpoint, then you would select that computer as the Audio Zone under Settings>Audio in Roon. Roon will see the 2nd computer as the Zone.
Oh perfect! I am glad you got that working. I think the microRendu is working, as you got it to show up in Roon earlier. I think it just may be some settings. Have you gone into the microRendu’s GUI interface (www.sonicorbiter.com) and set it to use Roon? You can also reset it from there. I am tagging @Jesus_Rodriguez , the owner of Sonore to help out if we can’t figure out how to get the microRendue working.
