Nuc connected via ethernet to wifi repeater. internet is a gigabit service.
Nuc connected via USB to Chord TT2 and then to Audeze LCD 4z (Single ended, 1/4inch) / cambridge amp (XLR) to Kef R5s. Blue sound node 2i (wireless) to cambridge amp (RCA) to Kef R5s. Via USB to Deckard to Audeze LCD 4z
No local library. Streaming only
Just connected Chord TT2 to set up. Plays really well without any sample rate changes. But once upsampling is selected to max PCM rate or Max PCM power 2, there is some distortion, white noise added to record and slow tempo playback.
no issue when on sample rate conversion - with “for compatiblity” selection or any other DSP filter selection or use without DSP. Tried restarting NUC, chord, amp etc…
Thanks for sharing what your experience has been like since adding a new audio endpoint. We’re very sorry you’re facing this, instead of enjoying music with your new device.
To really understand what might be going on, could you please share a screenshot of the Signal Path as the distortion is happening?
Hey @Dongwook_Kim have you found a solution? @beka I have no issues when up-sampling is limited to 384KHz . Do you have any suggestion to address here?
For now,
There are other nagging issues that probably point to the same core issue. When i play any music on roon via the TT2 - streaming fails - the error message from Roon is that there could be a network issue. the nuc is connected via ethernet and network is likely not an issue. I have had to re-start the nuc to get TT2 to play again.
Dont have this issue playing via my node 2i. So i feel this has to do with TT2 driver / windows issue
Also, It seems the ASIO driver in windows is maxed at 384 Khz - although the driver is named 44-768KHz… so not sure if this is a windows issue or the chord driver issue.
I downloaded and reinstalled the driver and a restart later it has started playing again - but same issues when using roon upsampling to 768
