Core: Roon Nucleus 1.8 Build 756
Ethernet connection
Netgear switch/router
Remote: Windows 10 PC, remote 1.8 Build 756
Cambridge Audio DACMagic connected via USB to PC, Driver 1.67.0, WASAPI
The DACMagic shows up under Settings > Audio but is not available as an audio zone. The problem occurred after a restart yesterday and I was able to fix it by reinstalling the DACMagic driver. Then it recurred today and reinstalling the DACMagic driver did not fix it. The DAC itself is working fine; I can play through it using the music player installed on my PC
